Installing K&N cold air intake
Old Apr 18, 2009 | 07:59 PM
benjamindcox's Avatar
Default Installing K&N cold air intake
Ok so my air filter box is right there when I open up the hood and can change out a filter or something in about 30 seconds. I have read reviews on the K&N cold air intake and someone said they had to remove their side panel to get to it others said their "box" had to be taken out from the bottom of the car. Am I missing something? I honestly have no idea how a cold air intake system works, could someone enlighten me on this subject. Thx
Old Apr 18, 2009 | 08:03 PM
Saint_Ali's Avatar
no its pretty simple,easily removed from the top of the car.Even people with no experience working on cars can do this
Old Apr 18, 2009 | 08:20 PM
Ok that's what I figured. I read at K&N reviews that a few people had some problems getting to their box, but like I said mine just sits right down into a whole easily removable and all that.
Thx for info.
Old Apr 18, 2009 | 10:05 PM
shawnz_90's Avatar
you take out all of the old stuff and put in the plastic tube. Its not that hard...
i thought i had a pic but only this one. http://viewmorepics.myspace.com/inde...ageID=34600328
Not to good and not to bad
but if u need more help ill take better pics
Old Apr 18, 2009 | 10:42 PM
Hmmm....when I put K&N CAI's on my 4th gen's the filter hung down below the metal shelf area where the stock filter box sits. The tube of the K&N snorkel fit through the existing hole, and the filter attached from below (after you remove the bottom plastic access panel of the car). There was no way for the filter to be pulled up through that hole, since the hole is way smaller than the filter. The filter being below like that is what makes it a cold air intake. The one shown in shawnz pics aren't a CAI because it's pulling in air from the engine compartment. It would be considered more of an HAI (hot air intake).
Old Apr 18, 2009 | 11:31 PM
the way ^ explained it is right on for what u have to do. the hardest part is putting the filter on. just go to summitt and click on the instructions. thatll give you a better idea of what it entails. i just did a moroso with a vortec elbow on my car yesterday and it took less than an hour to do the cai. i have had the k&n before and i think i like the moroso a little better. almost the same thing but the moroso is mounted better. doesnt move at all but that could be because of the solid elbow at the tb. the k&n on my first 93 did move a little (potential rattle) but had the rubber tb elbow on it.
Old Apr 18, 2009 | 11:36 PM
chernabog's Avatar
Are you running a 93-97 or a 98+? From what you're saying, it sounds like a 98+, which has the air filter box on top. The 3.4L from what I remember ran down into the area behind a headlight. If you are running the 3.8L, these are the pics of what you can do. However, its a tight radius getting in behind the radiator. Mine snapped and went under the car, and I rolled over $150 worth of parts and K&N Air Filters.
http://s27.photobucket.com/albums/c1...t=DSCF4007.jpg
http://s27.photobucket.com/albums/c1...t=DSCF4005.jpg
http://s27.photobucket.com/albums/c1...CF4004-1-1.jpg
That first pic is really revision 2.0. The first time I did it, it was behind the radiator and against the belt. Bad idea. That was more down behind the radiator but blocking the exhaust fan. Bad idea number 2. I finally got it all the way under the car, about 2 inches of breathing space below the pickup in front of the radiator. It's a lot of weight, and I went cheap and used Spectre pipes.
Old Apr 19, 2009 | 06:57 PM
shawnz_90's Avatar
hugh??? you might be talking about the old intake the (blue one) but yeah the k&n drops down through the existing hole and you need to drill and bold on a plastic thing that holds the intake in place and keeps it from wobbleing but i added the link with the top of the intake you can kinda see it
Old Apr 19, 2009 | 11:19 PM
Yeah, I was talking about the blue one in your pic album. I didn't see a K&N, unless that came later in the album that I didn't see.
Old Apr 19, 2009 | 11:24 PM
evilkal's Avatar
Get a new lid and a K&N filter and your stock air box will perform just as well as the K&N CAI
