I'm Leaking????
RE: I'm Leaking????
I can try, first power steering, check hoses and power steering pump. for radiator check hoses and radiator. you may have to clean area and then check after to see where it is coming from.......SFC
RE: I'm Leaking????
Do as described in the above post. Be sure to clean the fins of the radiator and check for pin holes. It wouldn't hurt to powerwash the affected parts (without getting the brunt of the spray into any electrical connections or sensors). A clean slate makes finding leaks much easier.
