Ignition Problems
Old May 18, 2006 | 02:28 PM
psycho3112's Avatar
Default Ignition Problems
I Have A 1994 3.4L v6....I am having problems with turning the car on. when i stick the key in, it won't even turn forward or backwards, also the steering wheel will not lock! it sounds like it will but then it quickly unlocks! I need detailed instructions on how to fix this!
Old May 19, 2006 | 01:35 PM
Default RE: Ignition Problems
I would think you have problems with the ignition switch. The procedure to replace it is fairly simple, but because youcan accidentally set off the air bag, it should be done while using the instructions on a service manual.
mattie08
82-92 V6 Tech
12
Feb 17, 2009 02:25 PM
96 Row
Apr 16, 2008 02:16 PM
96 Row
Mar 17, 2008 12:03 PM
Tat2freak
Nov 27, 2006 09:41 PM
speed1994
May 18, 2006 06:27 PM
