Ignition key stuck!
Anyone ever had their ignition key stuck in the key cylinder? Key is not bent and it will start the car. Just can't turn it back to the off position and remove it from the cylinder. Feels like maybe one of the cylinder pins or whatever they are called is catching on it as you try to remove it. Does anyone know how to get it out?
Stick or automatic? Have you had the colum apart recently? Is the steering wheel on a bind? or does it move freely?
To me that does not sound like a cyclinder problem. Sound more like its a problem with the cyclinder locking the steering wheel.
Well, I first thought it was because the auto was not fully locked into park, check that, not the problem, the checked to see if wheel was in a bind by turning it left and right as I tried to remove the key but The key will not rotate back to the final position where one can slide the key out. Never had the column apart. I finally worked it back and forth until it moved to the off position so the key could be removed. Now just have to figure out what is going on.
Wore out key or lock cylinder problem. Had the same problem on my 3rd gen car and the problem is NOT going to cure itself, it is only going to get worse. Note: getting a new key cut from the old one is not the solution, just new lock cylinder and key set solved my problem.
Maybe I am wrong but I do not remember ever seeing a cyclinder causeing the key not to turn all the way off. The tumblers stop the key from turning on but I do not see how they can stop a key from turning off. I guess it is possible. I have seen tumblers fail and you could even take the keys out of the car while it was running. The car still was able to turn all the way off. It sounds to me more like the gear the ignition is engaging is binding up. Could be tranny adjustment or something failed mechanicly in the colum. If you are 100% sure its not the tranny adjustment the repair procedure for both problems is the same. The colum needs to come apart. Once you strip the colum down to the point you could take out the cyclinder you will be able to see whats going on. If you find it is the cyclinder you can take your key and old cyclinder to your local dealer and the parts guy should be able to hook you up on the spot.
With proof of onwership the dealer can make a new key by the vin number.
90% of the time I have seen this problem it has been a tranny adjustment issue. The reason I asked if it has been a part before is because there are a lot of ways to get the colum together wrong and that will cause all kinds of problems.
