Ignition issues with a 95' 3.4
I have a 95 camaro and I'm not getting any spark from cylinders 3,5, and 6. Ive got all new plugs and wires. My next step was replacing the coil packs but cylinder 3 is on the same pack as cylinder 4 and cylinder 4 has spark. I assume if the pack was busted both would lack spark.
Ideas?
Are there any common 3.4 issues I should know about?
Ideas?
According to the FSM the coil layout shows a different cylinder pairing. 1 & 4, 6 & 3, 2 & 5. In certain conditions, an internally open coil may still be able to fire on one side. Try replacing both coils (6 & 3, and 2 & 5). If the coils have been moved around the numbering will be off and cause confusion. Also check out the ignition module under the coils and check the connector for corrosion.
