ignition/coils
Old Jun 9, 2007 | 02:22 PM
ranger4620's Avatar
Default ignition/coils
i am about to upgrade my ignition and coils. i am looking at MSD for both w/ the 8mm wires. is it worth the money? or should i consider another brand? would would be the best setup?
Old Jun 9, 2007 | 02:51 PM
CamaroKid16's Avatar
Default RE: ignition/coils
It's better to have too much wire. I have 8.5 on a v6. Not necessary but i have them and dont have to worry about them. With new coils, the big wires will make sure to take full advantage of that. I say go for the big wires. And MSD knows there **** if anybody.
Old Jun 9, 2007 | 03:59 PM
Keep in mind that as good as MSD is, if your ignition is working properly now, you aren't going to feel much of difference, or possibly none at all. The reason to upgrade the ignition is when you have seriously modified the engine, and the stock ignition ,due to higher compression or RPM range can no longer fire the plugs consistently.
Old Jun 9, 2007 | 09:29 PM
libertyforall1776's Avatar
Or you can go with AC Delco or similar that offer a lifetime warranty at Murray's and you are set for life! ;-) Why go overkill on a V6, unless you have a real need?
Old Jun 10, 2007 | 12:13 AM
if you're going to do it... you might as well do it so u have more then u need rather then not enough. Besides a good ignition system never hurts cold start ups or accesory life
Old Jun 14, 2007 | 07:13 PM
ranger4620's Avatar
all very good points, thank you
Old Jun 14, 2007 | 07:17 PM
usarmyrangrs's Avatar
Indeed. AC Delco would be the best way to go. Ignition upgrades really only lengthen longevity of the components. As Pete said, you won't notice much, if any, of a performance gain. The computer directly controls the advance and retardation of the spark, so there's not much left to do.
J-Factor
Jun 4, 2015 11:07 PM
Bandit 43
Feb 8, 2011 12:02 PM
ChevyManCam
Jan 10, 2011 12:34 PM
HEAVYCHEVYMAYNE.
Jan 2, 2008 01:42 PM
mgray
Jun 6, 2007 02:44 PM
