idling real bad
Old 01-16-2013, 03:18 PM
fasttony350's Avatar
Default idling real bad
i just swapped a new motor in my 1996 3.8 and i believe i routed some of the vacuum lines wrong. anybody have a complete vacuum diagram for this motor or close up pictures. it starts and goes up to 3,000 rpm then drops and will stall if i don't give it gas. then i tap the pedal then the rpms shoot back high again then drop after a few seconds again. i got a random misfire code but know my timing,spark,and injectors are all good. i am pretty sure i screwed up the vacuum routing but can't find any decent diagrams.
Old 01-16-2013, 04:33 PM
Everett#2390's Avatar
There might be a vacuum hose diagram on the hood.
Old 01-16-2013, 04:45 PM
BasicConcepts's Avatar
Technical User
Old 01-17-2013, 01:27 PM
there is no diagram on my hood and i used that diagram basic sent however it doesn't show where the to acsry is? i see a port with 3 vacuum lines and one farther down however it doesn't show excatly where and i am pretty sure thats the hose causing me the problem because it works with the regulator.. can anyone send me pics of excatly where that hose plugs into
Old 01-18-2013, 05:49 AM
ACSRY is accessory and would go inside the interior through a grommet on the pass side firewall to the Heater/A/C system to control the actuator doors, ie, vents, defrost, temperature, and inside/outside air.
Along with this accessory hose, is a cannister/reservior also, like a storage tank.
Old 01-18-2013, 06:26 AM
Old mechanics trick. Just pinch off each line one at a time with a pair of needle nose plyers. Once you know whick line is causing the issue then you know where to start.
I think the only Vacuum hose the motor needs to idle in your garage is the MAP sensor. Everything else you could plug and reconnect one at a time. Did you have the PCV valve out?
Old 01-18-2013, 08:43 AM
Technical User
There's a vac line in one of the wiring harnesses near the firewall on the passenger side, that goes to the heater box to control the doors.
Old 01-18-2013, 10:37 AM
the pcv valve i had out but put it back..the map sensor i had to buy a new one and installed it however the vacuum line coming out of it i don't remember where it goes
Old 01-22-2013, 04:22 PM
You need to make sure you got everything back in right on the PVC valve. You can get a nasty vacuum leak there if it is not together right.
fasttony350
09-06-2013 06:42 PM
elieser200
02-16-2012 02:17 PM
iLL95
11-18-2011 08:47 PM
numskull223
09-25-2011 10:07 PM
Quick Reply: idling real bad
