idles fast
RE: idles fast
How high does it go? It could be the TPS, IAC, or my Z-28 did that because the wires to the t/b were all screwed up at the firewall....
Need a little more info so dont replace anything based on what I said, wait for more experienced members.
RE: idles fast
if u have a 3.4 i can help u a lil
i had the same problem it is slowly goin away
ok so if u look on the driver side of the throttle body u will see the acceleration lever and cords
behind the lever there is a 6 point star spot it uses a t-10 star turn it to the right until the idle comes down
it worked for me but i also found a small hole in my EGR valve hose check that out too cause it could be a small hole
i got my idle during drive set at 990 it idles so good and has good acceleration
so check that out
so check that out
