Engine Races when cold, and idles fast when Hot
Old Mar 25, 2006 | 03:08 PM
rod's Avatar
rod
Default Engine Races when cold, and idles fast when Hot
My 83 Camaro with stock 305 and crossfire TBI injection runs good (just passed smog inspection).
However, when started in the morning, idle goes to about 1200 RPM, then over the next several seconds ramps up to around 1800. After a few minutes when the ECM goes into closed loop, the idle drops down to around 1100.
Obviously the ECM is getting some bad info. There is no "CHECK ENGINE" light and there are no stored error codes in the ECM.
The engine has a new TPS, MAP and O2 sensors. I've checked vacuum lines and they all appear to be in good condition.
Any other ideas of what could be causing this?
Thanks,
-rod
Old Mar 25, 2006 | 07:20 PM
TimmyTheWop89's Avatar
Default RE: Engine Races when cold, and idles fast when Hot
even 1100 rpm is a tiny bit high. try doing a simple idle decrease and drop it down to about 800.
Old Mar 26, 2006 | 01:01 PM
rod's Avatar
rod
Hmmm. I'll take a look for the idle adjustment.
Everybody said the idle is controlled by the computer, and the way the idle speed starts ramping up after start certainly seems like a computer thing. It sort of goes up a little then pauses, then goes up a little more then pauses. It's kind of "hunting" for an appropriate idle speed.
A few days ago I went to start it up on a really hot afternoon, and it actually didn't do the racing thing. It started up and idled nicely instead of like it does when it's cold.
Old Mar 27, 2006 | 09:56 PM
Being that it idled good on a hot day, you may want to check the Engine Coolant Temp, ECT (not the temp gauge sensor) and Air Intake Temp, IAT sensors as they may be sending the wrong data to the computer. These sensors work toghether. Also check the idle control valve , if your car uses one, make sure it is clean and not sticking.
Old Apr 16, 2006 | 01:36 PM
rod's Avatar
rod
Hmmm. Now that's some good advice. I didn't even know there was an Air Intake Temp.
How can I tell the difference between the Coolant Temp sensor for the ECM and the Temp sensor for the gauge?
Is the Idle control valve the IAC (Idle Air Control)? It's got two since I've got two throttle bodies.
Thanks!
< Message edited by z28pete -- 3/27/2006 8:14:24 PM >
Old Apr 16, 2006 | 03:31 PM
The ECT is located iether on the thermostat housing (TBI) ,or on the front of the intake manifold (TPI). The IAT sesor lives underneath the plenum, and the plenum has to be removed in ordr to get to it.
Jmanfritz
Mar 11, 2010 08:38 PM
wiskow
Feb 28, 2010 07:59 PM
skillz
Mar 30, 2008 01:18 PM
peter
Feb 28, 2008 07:03 PM
Spartan66
Nov 7, 2007 12:16 PM
