Idler removal
Old Feb 7, 2012 | 07:40 PM
Chevy101's Avatar
Default Idler removal
How do you remove the idler pulleyon a 98 v6?
Old Feb 12, 2012 | 02:11 PM
osduck5's Avatar
Are you needing to replace the entire assy or just the idler pulley? You can unscrew the idler and replace just that piece if the bearing is bad, However, if it is tilting forward, the spring assy needs to be replaced and to do that, you have to replace the entire assy.
camaroteen82
Feb 8, 2014 04:18 PM
Sewperdave
Jul 17, 2011 03:23 PM
RFxCamaro
Jan 23, 2011 02:27 AM
Foskey
Jan 9, 2007 04:10 PM
