Idle Issues
Old 08-01-2013, 05:35 AM
should idle at about 450 rpms with iac closed all the way. to set base idle you need to have the iac closed and the system in diagnostic mode, in this mode iac should be closed all the way, if not its not set right. to set idle adjust set screw.
Old 08-01-2013, 09:13 AM
94CamaroV6's Avatar
With IAC closed on cold start / not running for 1+hr, idle is ~1k. After about 5 minutes to warm up, idle shifts to 1.4k-1.6k. If you happen to have to procedure for relearning as you say, please let me know. I didn't think you could change the screw position on the V6. I could be wrong though.
Old 08-01-2013, 12:00 PM
no, dang it, i was thinking lt1.
camaroteen82
03-30-2014 04:02 PM
greenarrow
12-25-2013 02:32 PM
chasec
10-09-2010 02:30 PM
robmnrd
06-08-2010 12:58 AM
xDeath
11-15-2009 03:31 AM
Quick Reply: Idle Issues
