I smell coolant!!
I smell coolant!!
It's not leaking (Visablly) and I have not lost any coolant. Anyone have any ideas as to why I would smell it when I get out?
Also, the lovely previous owner put a straight pipe on (Muffler Delete) and I'm guess never tuned it. Do you think the lack of back pressure will hurt the motor. Should I run out and buy a muffler?
Who's turn is it to respond to the "less back pressure is bad" myth? Anybody? I've lost track!
As far as the coolant smell, you could have very a small leak that's hitting your exhaust as you drive, and it will take a while for it to show lower in your reservoir.
Been there, seen that, had it bookmarked. Thanks tho!
Here are a couple more I had saved. Don't mind the ricer site on the second one, it's still info:
Exhaust backpressure the myth - ThumperTalk
Exhaust: The straight scoop on backpressure - DSM Forums
Back pressure, my favorite subject. lol I am glad that part of the question has been answered for the umpteenth time. One thing I would like to add regarding the smell of coolant, there is always the possibility that a minor leak in the heater core can cause a good deal of coolant aroma.
OK back to the real problem, You need to do a pressure test of your coolant system. Most likely its a small leak but could get big fast. Coolant system failure and the main reason for engine replacement for the 3800
You can borrow a pressure tester from most chain parts stores and head over to youtube and search coolant pressure test for how to videos
AnalyzeFaith
12-05-2010 05:54 PM
