How screwed am i?
Old Jun 4, 2008 | 06:43 PM
onspeed's Avatar
Default How screwed am i?
Long story short, the iron piece that the oil pressure sensor screws into is cracked, thus making me leak oil everywhere. How badly ****ed am i?
Old Jun 4, 2008 | 07:20 PM
Saint_Ali's Avatar
Default RE: How screwed am i?
how badly is it cracked ? you could use some jb weld if it isnt too bad, or go to a shop and have them weld it so it holds
Old Jun 4, 2008 | 08:11 PM
onspeed's Avatar
crack is on the left side. I looked at a parts manual, thats actually a seperate pice from the block (thank god) however, i'm having trouble finding it on rockauto and gmpartsdirect. the part number is 24508439 and its listed on page 41-42 of the "93-02 camaro parts manual.pdf " called "adapter,oil fltr (w/bypass vlv) "
Old Jun 4, 2008 | 11:00 PM
I haven't messed with one on this model yet, but most, if not all of the fittings on the engine (sensors, screw in plugs, etc.), are NPT (national pipe threads). You just may get lucky and find a fitting/adapter that will work at your local hardware store.
Old Jun 7, 2008 | 05:35 AM
greg w's Avatar
ORIGINAL: Camaro 69
Thats what I was thinking as well.Keep in mind, pipe threads are tapered. You dont have to put a ton of torque to them to get them to seal. Good luck
FSTKMARO
Apr 29, 2013 05:51 AM
camaro86monster2506
Jan 6, 2012 10:46 PM
Potterboy
Aug 29, 2010 12:08 AM
Z28 M4N
Oct 15, 2007 08:14 PM
vettemanosteel
Feb 22, 2007 11:03 PM
