How to replace coolant temp sensor? 95 3.4L
Old 03-05-2010 | 01:02 PM
Racer's Avatar
Default How to replace coolant temp sensor? 95 3.4L
I have 95 3.4L Camaro. Need to replace the coolant temp sensor which is next to the thermostat housing. It appears to be nearly impossible to get to. Do you have to remove the whole plenum or is there a trick to doing it? I am hoping for a trick.
Old 03-05-2010 | 01:06 PM
evilkal's Avatar
Have to tried taking off the thermostat housing to see if that helps you any better? Is the ignition in the way or what (sorry I don't know on a 3.4)?
Old 03-10-2010 | 09:55 PM
trippymg's Avatar
What your looking at is not the coolant temp sensor i believe thats the oil pressure sensor/sender the cts is on the driver side right behind the power steering pump
Old 03-11-2010 | 06:43 AM
Racer's Avatar
Can't be. Its threaded into the water jacket.
Oil pressure unit is down by the oil filter.
Old 03-12-2010 | 06:44 AM
trippymg's Avatar
thats exactly where the temp sensor is because mines faulty and sometimes unplugs causing my guage not to work and when i plug it in right by the power steering pump the guage turns on, then whats the sensor mounted right by the valve cover under the 3.4 plenum center front of the motor
Old 08-21-2011 | 02:03 PM
m-samuels@sbcglobal.net's Avatar
The coolant temp sending unit is behind power steering fluid refill.So whats the (sensor) right beside the thermostat on this 3.4 camaro 95??
Old 08-22-2011 | 02:41 PM
slick's camaro's Avatar
air temp sensor is by the thermostat. the coolant temp is on the driver side head behind the power steering pump.
Old 08-23-2011 | 10:11 AM
Ok thx haynes manuel didnt show air temp sensor
Old 08-23-2011 | 08:33 PM
What size socket u think I need to remove?
Old 08-23-2011 | 09:12 PM
its been a while but I think it was a deep socket 5/8
Quick Reply: How to replace coolant temp sensor? 95 3.4L
