How do you beat the 115 redline limit?
Old Nov 26, 2011 | 08:34 PM
9434V6's Avatar
Originally Posted by 3800camaro
115 sounds like the speed limiter on the v6 cars. The rev limiter is around 6200-6500. I've bounced off it a few times by accident. 5500 and 115 mph sounds like a 3rd gear speed limit. The 3.4l cars don't have the power to push any faster going into od. Even the 3.8 have hard times.
That could explain it. 155 is the speed limiter on it and my rev limit is 5600 rpms. makes sense with not being able to run overdrive and hitting 5500 since its in 3rd. so what should i change to fix this? just more power so it can run the overdrive gear at that speed and than remove the speed govern?
Old Nov 27, 2011 | 08:50 AM
I would get the speed limiter removed and just start adding power where you can. If it is a tired 3.4 You may only get to 120-12.
Just word of warning. You really need to be sure the car is in top notch shape and I don't mean it passed a saftey inspection. You really need to go over the car. Something like a loose ball joint or tie rod end can cause a "speed wobble" The speed wobble can cause things to break very quicly. Your chance of surviving a car crash with no cage at 120 MPH is not great. These cars are very easy to drive at high speeds (unlike older ones) but none of the saftey stuff was designed or tested for speeds that high.
Old Nov 29, 2011 | 03:32 PM
9434V6's Avatar
Yea, I already planned on it. Im going over the car replacing everything. I just wanted to know this for future reference. I wont be pushing it that hard until the car is completely worked over. I am mainly using it as a show car, but Im still curious what kind of quarter mile time I can squeeze out of it.
Old Nov 29, 2011 | 06:19 PM
Failed Devices's Avatar
the speed limiter won't help your 1/4 mile time, you won't be trapping any where near those speeds
Old Nov 29, 2011 | 07:16 PM
3800camaro's Avatar
1/4 mile you might get mid 16's at 80mph.
Old Dec 5, 2011 | 02:00 PM
9434V6's Avatar
Well I did something right. She now hits 115mph in 4th gear at 4400rpms. And if it takes 16 seconds for a quarter mile, id be past 80mph. my 0-60 is 7.2 seconds. and it does not take that long to get to just 80. I dont know why she wasnt hitting 4th gear at 115mph before but its fine now. Looks like I can get new tires and end up removing the speed limiter than. Add some more power and I should be able to get a decently low time on the 1/4 mile.
Old Dec 5, 2011 | 03:37 PM
3800camaro's Avatar
Decently low as in 15?
Old Dec 5, 2011 | 04:06 PM
Cheeks's Avatar
August 2011 ROTM
I would be VERY impressed if you cracked a 15.9 in that car at 80mph, the drag strip is a VERY humbling place, trust me
Old Dec 5, 2011 | 04:15 PM
New your car was 16.6
165 HP at the fly wheel with a 3400lb car
1/4 Mile ET Calculator
That thing seems pretty accurate. It list my car at 15.7 stock and with a 25HP add on at the fly wheel it list my time at 15.17. My Ipod list my 1/4 time at 15.1.
Old Dec 5, 2011 | 04:27 PM
  #20
Cheeks's Avatar
August 2011 ROTM
I'm not sure that calculator is "dead on"
its saying I make 680whp to go 10.42, I can assure you I don't make that much. If we're going off calculators, I've found this to be the closest to accurate
