Help Swapping One wheeler Peeler to 2001 3.23 Auburn Posi Drums>Disc Question
I just picked up a 2001 Camaro Rear Diff to swap into my 1995 3.4 Camaro. From what I researched it is a direct swap, is this true?. The 2001 Rear Differential is a 3.23 Auburn Posi with new ring an pinion seal, axle seals, and new brakes. The rear diff is also made for a 3 channel ABS system which matches my current ABS system since i have no TCS. My only concern is the brakes, I currently have drums on mine, since the brake lines currently go directly to the brakes, what modifications would I have to do to connect the brake lines from the disc brakes of my new rear differential to the current brake lines in my car which go directly to the drums? Also please inform me of any other concerns I should know about, thanks. I purchased the new rear diff to get better traction and stopping power, It is for my daily driver.
yeah, Thanks, I took a look at it and I found a hose that should be a direct, fit. I take it off wednesday so I'll see if i need the fitting. BTW, Can I use the same sway bar? Thank you.
