HELP starting Issue
ok so when i cold start my car it turns over but its a low rpm's and sounds like its about to die. Also one time i tried to start it and it drained my battery. I took it to autozone and they scanned my car and it wasn't throwing codes.They tested my alternator , battery and starter and they said it was good. Any ideas on why my car won't start some times??? Thanx in advance
Had the same issue a couple weeks ago. New properly gapped plugs and new wires and it's a new car. The emphasis in the symptoms you're describing is "Cold start" I also noticed the problem if it was super damp in the morning. Hope that does it for you!
Thanks,
Tom
Thanks,
Tom
