Help!!!
Old 03-05-2013, 08:43 PM
jml2002's Avatar
Going back to wat the codes say. I'm stumbling away from it. It was 1120, 1220, 1221, 1516. 1120 and 1220 are tps 1 and 2. 1221 is tps 1 and 2 correlation. 1516 was throttle actuator control throttle actuator pedal position performance or something. This is the sensor mounted to the top of pedal right? I pulled the pedal out the car to get a better look at it. Its a big rectangle box. Only one plug. 24 pin plug. So codesaresaying something bout this thing. Only thing is I can't find this part at a auto parts store looks like a dealer part only. Does anyone know bout this part. I guess only the 2000 and later have it this way.
  #52
Old 03-05-2013, 08:45 PM
jml2002's Avatar
I guess I'm buying from dealer
  #53
Old 03-05-2013, 09:33 PM
parts book/manual here have a look. http://performanceworks1.com/PDF%20F...s%20Manual.pdf
  #54
You could pick one up at a yard, My guess is it is going to be pricey. I have been on this site since 2007 and yours will be the first one I have heard of going bad.
  #55
Old 03-10-2013, 04:29 PM
jml2002's Avatar
Does anyone have a picture of this module. I want to compair
  #56
Old 03-10-2013, 08:58 PM
part number 24506358 first is best price, 300 bucks. better have yours checked to make sure your replacing a failing part.
GM Parts Direct: Your direct source for Genuine GM Parts 300bucks
24506358 - GM PEDAL 367 bucks
  #57
Old 03-11-2013, 06:51 PM
jml2002's Avatar
Ok how do I test this to check proper working condition. I can't find anything on how to do this for this specific part.
  #58
Old 03-11-2013, 06:52 PM
jml2002's Avatar
Its a 24 pin plug
  #59
Old 03-11-2013, 08:01 PM
heres the diagnostic chart DTC P1516 you will need a diagnostic machine to see the results.
  #60
Old 03-17-2013, 11:27 AM
jml2002's Avatar
I'm buying a new TAC from gmpartsdirect.com part #24506358. My question is does this have to be programed to my car. Or learn process. Or is it a plug and play thing? I emailed them and their reply back was.: We don't have access to that information.
