help!!!
Old 05-15-2011 | 11:10 PM
slaning04's Avatar
Default help!!!
i have a 99 camaro 3.8 and a few days ago the check engine light came on. when going from 0 to about 40 or 50 mph the car runs like **** with a real bad hestitation and the seems to run fine. i got a obd reading p0303 cylinder 3 misfire reading. please help! will the car run like i explained because of this reading?
Old 05-15-2011 | 11:16 PM
Chaotic94's Avatar
September 2011 ROTM
Yes. Sounds like You need some spark plugs and plug wires. It could also be a ignition coil that has gone bad.
Old 05-16-2011 | 12:01 AM
slaning04's Avatar
ok...i just ordered a ignition coil pack. ill try that first ad see if that fixes the problem. if not ill change the plugs
Old 05-16-2011 | 05:38 PM
slaning04's Avatar
Default help!
update....there is white smoke coming out of the exhaust. i checked the oil and that looks ok but coolant looks brown and there is a light brown.....looks kinda like sludge on the inside of the cap and on the plastic strip that runs from the overflow cap down into the overflow. any ideas?
Old 05-16-2011 | 09:59 PM
Chaotic94's Avatar
September 2011 ROTM
Sounds like you have some oil in your coolant to me. That would be bad.
Old 07-06-2011 | 04:01 PM
shypes3's Avatar
yes it sounds like a head gasket. Better that than a cracked head. (cheaper I mean, if you can do it yourself,) Either way not good though. good luck...
