Headlights
I was looking for a new set of headlights for my 2002 camaro v6 I picked up a set from PFYC but they did not fit so i had to return them. Has anyone picked up a set for theres that fit? If so where did you get them from? Also is there a difference in the 2001 body to the 2002?
Be carefully especially if you're looking to buy online. I just bout a set of projector headlights for my 01 and they are very cheaply made. First off the rubber seal around both lights wasn't installed in the right place so I had to rip it off and glue it back on where it should have been. Second the plastic around the adjustment/alignment screw broke on both of them when adjusting. Finally the little nut inside the plastic for the mount bolt broke free when tightening down, and the headlight is still loose, so I just left it.
