gutting the cat
Old 08-18-2008 | 09:20 PM
Shadowed_Stranger's Avatar
Default gutting the cat
OK guys this dude next door owns a viper and I have a 3.8 v6 so gutting the cat is the only way for a v6 to beat hhim right because i heard that if you dont gut the cat there is no way but if you do you will be putting down 500rwhp is that right?
SERIOUSLY though, I picked my car up from the AC place and all of a sudden I have zero power whatsoever. I don't get power flooring it and I can't get past 4k rpms. You hear a rattling after it is started up which my friend said was the cat (further confirming my suspicions). Then of course I check the engine light and it says catalytic converter failure or something like that.
So what all would be involved in gutting it, or more preferably, putting in a straight pipe? I have heard there are issues with O2 sensors when you gut the cat so it is not as easy as cut off and crowbar.
Old 08-18-2008 | 09:50 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: gutting the cat
it is just as easy as openning it up and ramming it with a rod of some sort.
Old 08-18-2008 | 09:51 PM
Chappie99's Avatar
your 02 sensor will throw a code to your ECU and will cause your SES lite to come on. You can get a cheep one on line for $100 bucks or so. A pluged CAT will kill your performance along with being very dangerous. It can get really hot(cherry red) and cause a fire. HAve seen it happen and its not cool.
Old 08-19-2008 | 12:14 PM
greg w's Avatar
Chappie99 is correct, except you wont get a o2 code if you dont have sensors after the cat.
Old 08-19-2008 | 12:30 PM
A friend of mine was telling me that gutting it will kill your gas mileage and performance because of the O2 sensor issue.
Also is there a way to accomplish this without the SES light to come on? I am not very mechanically inclined and the light lets me know whenever theres something wrong :/
Old 08-19-2008 | 01:36 PM
Ninja Administrator
the rear 02 sensors do not affect the PCM, they simply check the cat's performance. the SES light wont hurt anything, but u can buy 02 simulators online that will eliminate it
Old 08-20-2008 | 11:37 AM
Thanks, so is the removal easy? I looked a bit and it looks like I might have to cut it.
Another thing, if I cut it off would it just be easier to put a peice of pipe in it's place?
SixShooterCamaro
08-26-2009 12:10 AM
Street_Racer
12-17-2008 12:54 AM
92 Z28
06-27-2007 08:17 PM
