Grinds when shifting into reverse. HELP
Old 06-17-2010, 11:22 PM
Y2K's Avatar
Y2K
Y2K is offline
Originally Posted by Massey
If it does it from a stand still, clutch pushed down from start to engaging the gear then the clutch is dragging and needs to be addressed.
Massey
Yup,clutch drag pretty much assured.
Hopefully it's just a matter of adjustment but it could be a tired pressure plate as in time for a new clutch.
Old 06-17-2010, 11:28 PM
Chaotic94's Avatar
September 2011 ROTM
I know something is warped because when I take off and the clutch engages, the car vibrates. BADLY. Unless it's roasting the tires taking off fast Which happens alot lol. So I'm thinking the flywheel is warped. Ideas?
Old 06-17-2010, 11:41 PM
Massey's Avatar
More than likely you have a pressure plate that is going bad (the diaphram weakens and warps causing shuddering) or the master or slave are going bad and not able to hold the pressure properly. Both things will cause the problem. Also shuddering can be caused by broken springs in the clutch plate itself. Those can break from poor quality, or excessive torque (ie baking the tires off). When those little springs break the clutch plate cant accept the torque like it should and things go bad and you cant get a smooth take off.
Massey
Old 06-17-2010, 11:47 PM
Chaotic94's Avatar
September 2011 ROTM
Massey
So what exactly do I need to replace to fix all this? Clutch? Pressure plate? Both?
Old 06-18-2010, 12:03 AM
Massey's Avatar
Here ya go... This is where I would start and if you need get a new MC and SC.
http://www.oreillyauto.com/site/c/de...1351&ppt=C0015
Massey
Old 06-18-2010, 01:14 AM
Chaotic94's Avatar
September 2011 ROTM
Thanks alot man!
Old 06-18-2010, 01:20 AM
Massey's Avatar
No problem.
Massey
Old 06-18-2010, 01:51 AM
BasicConcepts's Avatar
Technical User
Massey
holy crap i paid like 230 for my clutch at pepboys there was no oreillys where i lived
Old 06-18-2010, 09:27 PM
Massey's Avatar
Check this map out.. are any of them near you?
http://www.oreillyauto.com/site/fi/s...s/29680/25.oap
Massey
  #20
Old 06-19-2010, 02:44 AM
Technical User
theres one like 6 miles away now but when i got the clutch i lived in ny and theres not 1 in the whole state
Quick Reply: Grinds when shifting into reverse. HELP
