grinding noise in rear of 95 v6?
Old Dec 29, 2007 | 10:21 PM
cwells793's Avatar
Default grinding noise in rear of 95 v6?
the rear brake shoes are ok,the differential fluid i changed and had no chuncks of metal,a little play in the axle shafts? ,the driveshaft is a 2 part and the rubber center bearing piece feels loose.could this be my problem?it grinds when moving whether the tranny in gear or neutral.205,000 miles on the rear end and drive shaft.
Old Dec 29, 2007 | 10:40 PM
Default RE: grinding noise in rear of 95 v6?
Check the rear axle bearings.
Godzilla179
Nov 26, 2010 02:11 PM
1999chevy
Feb 24, 2010 09:37 AM
BigRegUK
Sep 30, 2009 06:31 PM
Z28=RiceEater
Aug 13, 2009 12:24 AM
