gasoline leaking in oil?
Old May 26, 2011 | 10:37 PM
Katzen's Avatar
Default gasoline leaking in oil?
i just recently switched out the engine in my 98 (cracked block), so when i put the new one ine i checked the oil and it smell like their was gas in it,any i deas on where it would be? or if it is alarming? it is a 96 3800
Old May 26, 2011 | 10:54 PM
BasicConcepts's Avatar
Technical User
rings??? hows the performance of the car???
Old May 27, 2011 | 12:15 AM
where did the motor come from. is it rebuilt or used? what injectors did you use, new rebuilt or used?
Old May 27, 2011 | 08:37 AM
Was this a junk yard engine, and was it complete or was the intake off? Had the injectors and fuel rail been removed? If the injectors are removed without releasing pressure at the fuel rail first, the gas will release into the intake manifold, run down into the heads, through any open valves, down into the cylinders, past the rings, and into the oil pan. If that's the case, then don't sweat it, but certainly change the oil.
Old May 27, 2011 | 10:00 AM
Katzen's Avatar
oil was changed, before i ran it, it was freshly pulled from a camaro that had just came in at a junk yard, it was complete, and as for performance not sure completely as we only ran it through the yard but ran smoothly
Old May 27, 2011 | 11:39 AM
probly be a good idea to have the injectors cleaned and flow tested.
z28pete
Dec 8, 2013 11:31 AM
pcarollo
Sep 22, 2011 04:02 PM
Jerry95lt1
Nov 18, 2010 02:59 PM
00camaro00
LS Series Tech
Nov 28, 2006 10:16 AM
