Gas tank slow to fill
Old 12-01-2009 | 02:29 PM
nnewquist's Avatar
I just looked into it a little more, and your fuel tank filler tube has its own vent built in. It also has a spring-loaded stop-valve and an overfill prevention valve.
The overfill prevention valve ensures that only vapor goes to the canister. The stop valve actuates when a float reaches a certain height, and simulates the pressure that the gas pump looks for as a shut-off pressure. The vent runs along the length of the tube and is enclosed under the cap (look for a small hole, usually under the fill hole).
If you have the SES light showing, look at my previous post to figure it out. Otherwise, you probably need a new filler tube.
Old 12-01-2009 | 05:36 PM
jmeade65's Avatar
Thanks for the detailed posts. I do not have the SES light showing so looks like I'll have to check the vent in the fuller tube.
Javier Maldonado
10-24-2014 11:52 PM
ineversl33p
10-03-2010 03:32 AM
draggo144
82-92 V8 Tech
12-18-2008 06:41 PM
irocktheIROC
04-30-2008 02:57 PM
