Fuel Tank
Old Aug 4, 2010 | 03:16 PM
CamaroGuard96's Avatar
Default Fuel Tank
Okay so I'm having to drop the fuel tank so I can put a new fuel pump in. Is there any easier way to do it? I ask this because its staying 100+ outside with the index being 110+ and I have no access to a shop at this point of time. If there is not any easier way to do it, maybe some helpful tips?
Old Aug 4, 2010 | 06:06 PM
You have seen the trap door thread? Trap door makes it a 1 hour project.
http://www.worldisround.com/articles/12533/index.html
There is no easy way to drop the tank. Step one remove rear axle housing, Step two remove exhaust.
Old Aug 4, 2010 | 09:53 PM
mrfreez's Avatar
While you're dropping the tank, change the fuel pump! You'll be glad you did!
Old Aug 4, 2010 | 10:07 PM
^ And why was he needing to drop the tank in the first place?
Old Aug 5, 2010 | 09:17 AM
BoricuaHec01's Avatar
Man, I needed a new fuel pump because the gauge couldn't tell me how much gas I really had and the work cost me a thousand dollars. Real expensive but well worth it.
Old Aug 8, 2010 | 05:36 PM
Yea I only paid about 125.99 + shipping for a new fuel pump but now time to have fun putting it on. and what would be good to cut for that Gorn? Not exactly smart to use something that will make it go boom :|
Old Aug 8, 2010 | 07:19 PM
If you read the below thread you will see in one of the picture a angle grinder with a thin cutting disk. That is what I always use on sheet metal. There is about 3/8-1/2" between the tank and the floor. Read the whole thread cause we talk about the L shape we had to cut. Basicly cut the shape shown but then you will need to cut about a 2 inch wide "slot" that follows the lines till you find the connector.
https://camaroforums.com/forum/93-02-v6-tech-14/hard-time-starting-54029/
If that cheap pump you bought is an airtex (or a name like that) there is a 10-15% chance you will have to replace it in the first 30 days. I know I did . That price seems low for a complete unit. I paid $176, autozone and advanced auto wanted $200+ for it.
Old Aug 8, 2010 | 08:43 PM
lol I got it in and the cut wasn't pretty. used a chisel, hammer, tin snips, and channel locks . Its running now. so back to my project of restoring
and dont worry i didnt get that I got the this one from jegs:
http://www.jegs.com/i/Granatelli/467/GM722-2/10002/-1
craby
Mar 9, 2014 09:21 PM
old hoon
Nov 25, 2012 11:49 AM
1997 rs camaro
Jun 18, 2011 09:33 PM
shinwolf14
Aug 10, 2009 07:53 AM
kbar50
Feb 2, 2007 12:44 PM
