Fuel Pump Relay
Old May 2, 2010 | 06:26 PM
CamaroGuard96's Avatar
Default Fuel Pump Relay
Where is the fuel pump relay located on 96?
Old May 3, 2010 | 12:28 AM
BasicConcepts's Avatar
Technical User
In front of the driver kick panel near the footrest bracket under the carpet
i found this for the Z but it should be the same for em all
Old May 3, 2010 | 12:48 AM
Why do you ask? If you can hear your fuel pump priming when the key is turned on, the relay is fine. If not, then ok, go check it out.
chevyguy842010
Aug 19, 2011 01:55 PM
Chaotic94
Oct 11, 2010 02:54 PM
DevilGirl witha Halo
Apr 9, 2008 06:46 PM
buckfever
Dec 27, 2007 03:15 PM
tboneshep
Sep 22, 2005 09:41 PM
