Fuel pump recomendations
Old Mar 4, 2008 | 09:58 AM
cardana24's Avatar
Default Fuel pump recomendations
I am putting a 3.4 SFI engine into my Jeep Cherokee which has the 2.8 60 degree engine. Anyway The 2.8 is a carbed set up and has a manual fuel pump. I am going to run the SFI set up so I am going to need a different fuel pump. An electric higher pressuer in line pump. Do you guys have any recomendations?In my Haynes manual it says that with the key on but not running the pressure should be 41 to 47 psi and at idol it should be about 3 to 10 psi less. So what specs should I be looking for on a fuel pump? Do I not need one that can handle over 47 psi? Any help is appreciated. Again, I am going to run this in line, it will not be an in tank pump.
Old Mar 4, 2008 | 10:16 AM
02StanGT's Avatar
Default RE: Fuel pump recomendations
http://www.inlinefuelpumps.com/
I believe all electric fuel pumps can handle/obtain that pressure, though some will deliver more flow at that pressure. Check out that link. Walbro makes some good pumps. I would think the 190 LPH would suffice, but I'm no system expert by any means. I know others will chime in, and it would be best to get as much input as you can.
Old Mar 4, 2008 | 03:07 PM
cardana24's Avatar
I have a walbro 255 in my supercharged maxima and I have never had a problem with it. I am fine with the walbro pumps I just need to know which one to get. Where can I find the information about how much flow I need for the the 3.4?
nehidustin
Jun 28, 2010 07:30 PM
fearbunny
Jan 18, 2010 08:42 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
CAMAROADRUNNER
Jul 14, 2005 12:39 PM
