Fuel pump
Old 09-08-2011 | 02:48 PM
iLL95's Avatar
I Like to Party
Super Member
Default Fuel pump
So I needed to replace my fuel pump so I ordered one off of ebay and it said it was compatible and every other fuel pump that came up for '95 camaro' was the same so I bought it and it arrived today. I popped open the hatch and began cutting like in the video. I pulled the pump assembly out but where the pump should be is a bigger yellow thing. Is the silver pump inside?
It also came with these rubber hose rings, if I cut them they make the new hoses to attach to the new pump?
It came with the same strainer bag(whatever it's called forgot) but this one is a little smaller and green
So is there a way to get the yellow thing open? because I looked around online and no 4th gen camaro pump is yellow like that. and when I look inside the yellow thing I can see what looks like the top of my new pump.
Old 09-08-2011 | 03:00 PM
buck658's Avatar
there should be a set of clips that you can open the yellow thing with. but yes your pump is inside that, its just there to hold it and protect the pump
Old 09-08-2011 | 05:49 PM
vanquishfist's Avatar
The bag thing is a filter, I just helped a friend with a pump and it had a filter like that, just a little smaller on his car.
Old 09-08-2011 | 06:20 PM
iLL95's Avatar
I Like to Party
Super Member
Ok just got done replacing it, thanks :P
jon_uscg2001
08-25-2011 12:23 AM
nehidustin
06-28-2010 07:30 PM
carmodder
82-92 V8 Tech
06-23-2008 12:50 PM
BlueKitsune
10-05-2007 07:54 PM
johnson3034
05-25-2007 09:35 PM
Quick Reply: Fuel pump
