fuel pump
i did it by cutting the glued/welded areas and taking it apart put a granatelli 255 in it and used a plastic welder to put it back together. its workin fine but after doin a bit of reading, if i were to do it again i would use a gm oem pump with the bucket.
johnson3034
May 25, 2007 09:35 PM
