Frame worth fixing?
Frame worth fixing?
I ended up slamming into the curb and a pole on the way home from work and this is what happend. The wheel snapped off of the axle and the the impact from the pole destroyed the frame. My options are to repair the car in my garage or to sell the whole thing to someone wanting to sell the parts. Ill post pictures.
Not worth fixing. It kind of hard to say for 100% sure but based on the picture the whole unibody is tweaked. Your going to need 8-10 hours on a frame machine to get everything right. Then you would have to fix all the cosmedic stuff.
You can buy a nice straight V6 body for under a thousand and swap your motor and trans into it for a lot less money and time then you can fix this and you can do some upgrades along the way.
The reason I think the body is tweaked is the gap at the base of the door also I have replaced a few axles from sliding into curbs and most times when the hit is hard enough to bend the axle tube and the 1" plus thick alxle the mounting point for the axle housings are a mess. Those control arm mounts are not designed to take that much of a side impact.
But 2d picture can be very deceptive.
I want to strip the car down and part it out but I just dont have the room to do it and I dont want to risk breaking things. so I think im just going to sell the whole thing for someone else to part it out and ill just use the money as a down payment on another camaro with a v8.
