enigne cuting out
Old Aug 23, 2011 | 11:03 AM
nickb123's Avatar
Default enigne cuting out
My 3.8 in my camaro just developed a problem, it cuts out. Not very much, just like 3 little times if i give more gas at a low rpm in a high gear ( its a 5 speed). It has never done this before, but the old engine did... This engine is from a 05 buick park avenue with now 44,000 miles. it has all new gaskets (upper/lower intake, rear main, oil filter mount, TB, heater hose elbows), fuel filter, ac delco iridium plugs, 8.5 MSD wires, 180 thermostat and 1 new O2 sensor. Also I noticed at idle the oil pressure gauge mover alot, like 4-6 psi by the 60 mark. I used mobil 1 syn. oil and a fram tough guard filter. A friend scaned my car because the SES was on, it said, code P0332 (knock sensor 2 low input and P0420 (less than efficient cat). could those cause a problem? when he scanned he reset the computer and it has not came on, that was 500 miles ago.
Thanks for the help
Old Aug 23, 2011 | 01:02 PM
pull the plugs out and see if you can find a problem cylinder. just for piece of mind test the fuel pressure. look the wires over good for any damage or wear. how old are the coils? it may be a tired coil.
Old Aug 25, 2011 | 11:53 AM
nickb123's Avatar
well after driving it a little it seems to be fine. I didnt change any thing, that kinda odd...
Panther7011
May 2, 2014 12:50 AM
CasperOn20s
Jun 24, 2007 12:09 PM
