Sways
Old Aug 25, 2011 | 02:58 PM
KiddCamaro's Avatar
Default Sways
Can anyone tell me the sizes in (mm) for the front and rear sway bars of a stock 95 v6 3.4? I'm going to replaces the bushings but I don't wanna get the wrong size. Also I was thinking of getting bump-Stops, which ones should I go for?
Old Aug 25, 2011 | 03:34 PM
libertyforall1776's Avatar
OEM should be 28mm front, 15mm rear -- you can measure them yourself with a cheap vernier caliper. I would go with poly endlinks/bushings.
OEM bumpstops provide the smoothest transition, aftermarket poly ones would be more abrupt (harder material).
Old Aug 25, 2011 | 05:08 PM
vanquishfist's Avatar
That's what the stock were on mine when I measured them before upgrading to SS sways. I would suggest spraying the bolts and nuts with some kind of penetrating oil before, because those kind of parts like to break at that age.
libertyforall1776
Apr 12, 2011 12:17 PM
