egr valve
Old May 26, 2010 | 05:10 PM
BasicConcepts's Avatar
Technical User
Default egr valve
my buddy told me to get rid of my egr that it would help my car out a little but thats all he said can anyone elaborate on this for me will this help or hurt my car and do i just block off the valve or do i block off the line that goes to my intake too or can i just block off the line that goes to the intake if i do get rid of it how would i make it so i dont throw codes (no emissions testing where i live)
Old May 26, 2010 | 05:34 PM
egr only works a short time. will not have much effect on the performance either way. best to just leave it stock. the emmissions on these cars is minimal so getting rid of any of it will not gain a whole lot.
Old May 26, 2010 | 07:20 PM
Massey's Avatar
Like Craby said just leave it alone. It only works when you are cruising along and not needing any major HP. They do not really cost you any HP that you would ever notice. If you remove it you will throw codes and possably put your computer in limp home mode which will reduce HP as a way to prevent engine damage when some systems are not functioning properly.
Massey
Old May 26, 2010 | 09:04 PM
Technical User
but isnt the hot as hell recycled air a waste of my cai
Old May 26, 2010 | 09:47 PM
Vandee's Avatar
My Egr had a crack in the tube so i plugged the hole on the manifold and left the tube on the intake. i also plugged the tube at the bottom of the egr. it tripped the Egr low flow code but it didnt effect anything that i noticed. The guy at autozone removed the code so the light wont come on again.
Old May 26, 2010 | 10:00 PM
Vandee's Avatar
My dad had the idea to hook the egr up to the air intake after the filter that way it would still be taking air so a code wouldn't trip but it would be clean air not dirty hot air could this work?
Old May 26, 2010 | 10:35 PM
Technical User
im pretty sure the light will come on again the comp resets the codes like every 100 miles or something like that how long ago did you do this (i used to work at autozone its actually against the law for him to reset your codes)
Old May 26, 2010 | 10:37 PM
Technical User
wait does the egr flow from the exhaust to the intake or from the intake into the exhaust
Old May 26, 2010 | 10:40 PM
the computer is programed to compensate for the egr, like massey said the egr is not open at wot so when you need the full benifits of the cai it will be there.
Old May 27, 2010 | 01:40 AM
Technical User
ohh ok thanx guys i guess ill just leave it be less work i have to do
EagleRex
Oct 5, 2009 04:14 AM
Labyrinth9
Mar 20, 2008 09:15 AM
79camaro505
Feb 22, 2008 08:02 PM
3.4CamaroCDOG
Feb 1, 2008 07:22 PM
