Educate me! 3.8L V6 question.
If the cylinder was full of water your motor would be locked. You can not compress water, Not even a little. If the gasket is blown real bad you might be pushing the water out but it would be real slow. Most likely you have a spun bearing. That is the most common issue with cars that are hard to turn over by hand. Your on the right track. Pull the plugs and try to turn it over. If its tuff to turn over with no plugs you got major issues.
If you crank it with plugs out it should sound really fast due to the lack of compression. WARNING Make sure you disable the ignition before/if you try crank it with the plugs out. You would be amazed at how far the fire will shoot out of the spark plug hole. I would rather not talk about how I know
Geez, the plugs in this thing are a PITA to get out, even with it sitting on stands. The 96 we worked on previously seemed like it had alot more room around the plugs.
torque_is_good
07-02-2010 08:20 PM
