Still Throwing P102??
ok my original maf had a bigass crack on the top, and was throwing p102, so i order one from ebay, install it same thing. i contacted the seller, and they sent me a new one no hassle. i install it same problem errrr
! so this is like the last problem with the car n icant figure it out any suggestions, i checked the pigtail and about 6 inches of wire and it looked ok so idk
I had the same problem, and the mech. asked for 450$ replace the maf assembly. But had the sensor signal checked by another guy, and the problem was that it gave 0Hz sometimes, causing the mil to go off..! obviously it was a prob w/ the sensor, replaced the sensor, and it worked fine. On the otherhand, if the maf sensor reads less than 1200Hz, try spraying som alcohol near the intake while the engine is running, and if the sensor signal changes drastically, then you got a crack somewhere..!!! (you need to find som1 with a good obd2 scanner ..
All air must pass through the MAF before entering the throttle body. Any leaks will cause problems. Check the 20 Amp ENG SEN fuse. At the sensor connector check for 12 Volt at the PNK wire, Ground on the WHT wire, and signal on the YEL wire (H.F. AC sig. may need a scope to actually see it). Also make sure the YEL wire is not open or shorted to ground.
lol i kinda thought that the ecm could be goin out because of how old it is, so did you buy one and send it off, or did u buy it from a tuning company?
