Easiest way to replace your fuel pump
I finally found what I was looking for. The easiest way to get to your fuel pump and to replace itwithout pulling out all sorts of stuff from underneath the car. This shows how to do it from inside the trunk right behind your backseat. This is the hump part exactly behind the backseat. Once you lift up the carpet you can see from the links I provided how to do everything. I hope this helps all of you.
http://www.worldisround.com/articles/12533/index.html
http://www.taekwondoplus.org/z28/fuelpump.html
