DRIVER's SIDE WINDOW
Old Oct 29, 2007 | 11:00 PM
camaro4gc's Avatar
Default DRIVER's SIDE WINDOW
The driver's side window of my 2002 camaro won't go up all at once when the button is pressed, It will only go up an inch or two and then it stops, then I have to wait a couple of minutes again before it will work again but then it willnot close all the way. Anybody got any idea what it is and howto fix the problem?
Old Oct 30, 2007 | 08:47 AM
SilverBullet5's Avatar
Default RE: DRIVER's SIDE WINDOW
My dad has the same problem with his van (2000 GMC Savana) he has brought it back to the repair shop at the dealership numerous times and it still isn't fixed they have replaced the motor several times, so its probably wiring or something like that.
Old Oct 30, 2007 | 10:49 AM
apollo's Avatar
If you know how to, you caneasily find a new motor on ebay for the window. But if you dont know how, you can still save a lot of money by buying it off ebay and then having a trusted mechanic install it for you. I saved about 200 bucks buying a new radiator off ebay and having my mechanic install it for me.
Old Oct 30, 2007 | 12:16 PM
libertyforall1776's Avatar
Either the motor and or the regulator -- needs to be visually inspected. If the regulator is rusty, it won't work right... Best advice, replace both if in doubt.
Old Oct 30, 2007 | 05:38 PM
JaySan's Avatar
sounds like the window motor. Mine was doing that I replaced it and it works great now. Bought the window motor off ebay.
Old Oct 30, 2007 | 05:51 PM
maroman209's Avatar
mine does the same thing. on the drivers side it goes up very very slow, then about one inch from the top. it stops. sometimes it makes it all the way. others i have to push up the window
Old Oct 30, 2007 | 06:35 PM
Again, replace the regulator, and or motor....
Anderson_Z28
May 11, 2011 06:57 PM
Mtm5237
Feb 23, 2011 07:50 PM
golfballs
Feb 20, 2007 08:55 PM
camarocurt
Sep 29, 2006 11:27 PM
silverbullit
Jun 2, 2006 11:45 AM
