driver side window not sealing right
Old Jan 15, 2012 | 02:07 PM
shai one's Avatar
Default driver side window not sealing right
I am having issues with my window not seeling right and letting air and moisture in...ive taken the door panel out and adjusted with window brushes several times but I cant seem to make it flush with the weatherseal especially towards the back of the window where the seal is really bad...i even tried adjusting that triangle piece near the front of the side window but still no luck...any idea on how to adjust this so that i get a good seal?
Old Feb 27, 2012 | 10:45 AM
DanielWEWO's Avatar
I'm having the same issue I believe. On both sides of the car, the seal at the back of the window where it bends is coming out. I've tried sticking it back in but it won't stay. I'm not sure how to go about laying it in again. The seal itself is in great condition, but I really am clueless of the proper way to lay this in again.
Old Feb 27, 2012 | 10:31 PM
If the door is sagging because of bad hinges your going to need to get that fix first. When you say the "seal is real bad" do you mean its bad because it will not seal or that the seal itself is damaged? Your never going to get it to seal if the seal is damaged. The fix for that is a new seal.
Old Feb 27, 2012 | 10:48 PM
x01660's Avatar
The Mustang Hunter
Another thing is damage to the vehicle; has the car ever been in an accident? If so, the frame could be bent (or subframes. Whatever. You know what I mean. ), which could cause that problem.
I had the same issue in my convertible; you could actually see movement between the door and the body when I did 5000 RPM clutch dumps...
Good luck and let us know if you figure it out.
x01660
Sophm
Aug 3, 2013 11:00 PM
Mtm5237
Feb 23, 2011 07:50 PM
camaro4gc
Oct 30, 2007 06:35 PM
golfballs
Feb 20, 2007 08:55 PM
silverbullit
Jun 2, 2006 11:45 AM
