Door ajar switch/sensor?
Old Feb 20, 2012 | 07:36 PM
donhorn83's Avatar
Default Door ajar switch/sensor?
Hey guys.... Just purchased a Camaro a few weeks ago and have a few small problems that I'm trying to find the answers to.
1st: I seem to have a short somewhere thats causing my radio to not turn off. Im sure its not the radio as I have tried leaving my interior lights on then opening the door and I don't get that "ding ding" warning letting me know that I left my lights on. Any idea where this switch is located?
2nd: I am also having problems with my locks not locking all the way with either my key fob or electronic lock button. Some times it works.... sometimes it doesn't. Any help is greatly appreciated. Thanks!
PS 1999 Camaro 3.8 V6
Old Feb 20, 2012 | 08:39 PM
rachel11's Avatar
is that a aftermarket radio? Maybe someone wired it hot. Perhaps your locks need to be replaced, thats what happened to mine they became intermittent and sluggish.
Old Feb 21, 2012 | 01:15 AM
Spatfieya's Avatar
Like what Rachel said, sounds like whoever wired your radio has the radio turn on wired to constant 12v. Easy fix as long as they didn't chop the wiring harness behind said radio... then it becomes an issue unless your handy with a voltmeter & have wiring information.
And the locks do wear out over time. Seen a lot of these cars where they barely work if not at all. Ebay is a good source for new door locks.
Old Feb 21, 2012 | 06:14 AM
i think what is the rap in the older models was moved to the bcm. check the bcm mod in the how to and faq sticky at the top of the 4th gen section.
Old Feb 21, 2012 | 06:18 AM
Old Feb 21, 2012 | 10:04 AM
donhorn83's Avatar
Originally Posted by craby
Thanks for the link craby. I noticed that when you open the passenger door, the radio turns off like it should. So that's why I was thinking it had something to do with the door.
Old Feb 21, 2012 | 06:55 PM
donhorn83's Avatar
Just tried unlocking and opening the door with the key instead of the remote and noticed the interior light didn't come on. Definitely a problem with the door switch/sensor. Anyone have any ideas what I need to do next? Location and replacement? Thanks!
Old Feb 21, 2012 | 07:18 PM
i knew i had this somewhere, see where the door jam switch wires are, thats where the switch is.
Old Feb 21, 2012 | 07:37 PM
donhorn83's Avatar
Awesome craby! Thank you so much!
Old Feb 21, 2012 | 08:13 PM
donhorn83's Avatar
I cant seem to find these dang connectors anywhere... it looks like (in the 3 pic you posted) they are located on the frame of the car between where the door bolts on and where the wires go from the car to the door. Sorry if Im a noob but I cant seem to figure it out. Any other suggestions?
speedemon
Mar 21, 2015 02:13 PM
tonyfronce
Jul 10, 2012 10:33 AM
Javs_is_fat
Mar 19, 2012 07:28 PM
garretberg
Jul 29, 2010 09:32 PM
DDSracer
Apr 19, 2006 10:27 PM
