Donor Car?
Check out Socoms V8 conversion thread it will be the same amount of work. $550 is a good price but I would be a little worried about the motors condition for that cheap. $550 is cheap but it is nothing compared to the 80-100 hours of labor our going to have in the project. In the end you will wish you found the extra $400-500 and got a V8.
Grinding can be caused by a bad clutch or fail syncs in the transmission. You will have issues using any automatic with the 96 computer. Your 93's computer only controlled the lock up converter but the 96 manual computer will not do that. Plus your 93 has a detent cable that will need a mount made. That assumes you can find a torque converter that will work with a 3800 and a 93 trans.
