Does anyone know exactly..
Old Apr 18, 2007 | 03:29 PM
red99camaro's Avatar
Default Does anyone know exactly..
i'm in the process of flushingtheradiator on my '99 v6.. i put the flush in last night and i'm driving it now like the instructions say for 3-6 hrs. my question is how much antifreeze x water will i need to refill once i'm done flushing?
Old Apr 18, 2007 | 04:37 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: Does anyone know exactly..
Depends on the antifreeze. Some come premixed, some need mixing. The instructions on the jug should tell you. Unless you need to know the capacity which should be in your owners manual.
Old Apr 18, 2007 | 10:41 PM
usarmyrangrs's Avatar
I'd stick with the full strength 'green' antifreeze. You will need one part antifreeze to one part water. So for every gallon jug of antifreeze, use one jug of water.
Old Apr 19, 2007 | 12:05 AM
badinfluenceRS's Avatar
like stated above, read the directions on the bottle...
also, ditch the dex-cool 'orange' coolant and use the green stuff
Old Apr 19, 2007 | 02:09 AM
thanks yall... i do know i have to go 50/50 and i plan on gettin the green..but i was wondering if 1 bottle of antifreeze and 1 jug of water would be enough?
Old Apr 19, 2007 | 08:00 PM
We have a 3 gallon capacity, so 1.5 gallons of antifreeze, 1.5 gallons of water should be exactly right
Old Apr 20, 2007 | 10:11 AM
thanks usarmyrangrs
Old Apr 20, 2007 | 12:17 PM
BryantD's Avatar
Like usarmyrangrs said, we have a 3 gallon capacity. 1.5 antifreeze and 1.5 water. However, you are suppose to use the red antifreeze. (GM Dexcool). That is what our cars call for. Do not use the green stuff.
Old Apr 21, 2007 | 01:46 AM
Sure, it calls for the dexcool, but that doesn't make it superior. Prediluted antifreeze, where it may be more ecofriendly, is not so friendly within your cooling system. The green antifreeze is not as harsh at all. Every last automotive instructor I have encountered has said one thing and one thing only: REPLACE DEXCOOL ASAP!
For the sake of your cooling system and components, switch to green. Don't mix, however. Completely flush.
