distributor in 3.4 v6 1995 motor and other changes
Old Dec 18, 2011 | 06:57 PM
barry3.4's Avatar
Default distributor in 3.4 v6 1995 motor and other changes
changing to edlebrock and 4 barrel which dist just going with coil and dist to keep simple and inexpensive do i pull out all sensors from block and put in metal plugs as i am running simple street rod wiring . is it a s10 dist which years thanks barry
Old Dec 18, 2011 | 07:08 PM
barry3.4's Avatar
Default what changes to1995 camaro motor 3.4 to change to dist/carb motor
what changes do i need to make 1995 3.4 camaro motor using 4 v and intake and dist coil how about removing sensors and putting in plugs anything else going to change cam and putting in cam. and headers keeping stock bore and stroke for now putting eng in british mgb only want about 180 to 190 hp thanks barry
Old Dec 18, 2011 | 08:07 PM
BasicConcepts's Avatar
Technical User
this isnt going to work you cant just slap a carb on a car and expect it to run... also a dizzy wont fit under the cowl. the 3.4 is the worst platform to try and make power save yourself a lot of time and money (not to mention the perfectly good running car) and sell it and get a 96+ 3800 (around 200hp)
Old Dec 18, 2011 | 08:15 PM
B.C., he mentioned it in another thread and here, he's putting the 3.4 into an MGB.
Old Dec 18, 2011 | 08:19 PM
Technical User
ohhh whoops didnt see that one sry bro
Old Dec 18, 2011 | 08:21 PM
Threads are merged.
Barry, please make only one thread per subject, thanks.
Old Dec 18, 2011 | 08:33 PM
To answer your question, you are going to be making the engine old-school, with a stand-alone, non computer controlled ignition and carb.
So yes, you would be pulling the original block sensors and plugging the holes.
I believe this link should tell the rest of the story. This is your plan I take it? Brian Laughlin's 1969 MGB GT with GM 3.4L 60-degree V6
Old Feb 28, 2021 | 12:01 PM
Mickey Adams Hill's Avatar
I need information on the same thing. I'm swapping in a 1995 Camaro motor 3.4 in my 1985.
dr_altair
May 30, 2020 12:06 AM
camarowner
Aug 13, 2008 11:29 AM
crgm101
Dec 28, 2007 09:08 PM
lewispartscenter
Oct 23, 2007 12:49 PM
black34v6
Jan 27, 2007 01:45 AM
