different front cover gaskets?
Old Jun 14, 2010 | 07:50 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default different front cover gaskets?
the front cover i gasket i pulled off my girlfriend's 3.8 was a rubber and gasket combo type seal, and the replacement is a thin metal. is this the correct front cover gasket, or do i need to find one like the factory?
Old Jun 14, 2010 | 09:37 PM
osduck5's Avatar
What year? I have not replaced the front cover gasket on one but all the other gaskets that I have bought from the auto parts stores look exactly like the ones I was replacing. I have replaced the water pump gasket and it was like you discribed but it is suppose to have sealant put on both sides before installing water pump. Maybe the cover gasket is the same way. The parts store that you bought it from should be able to tell you if it is. Maybe someone who has replaced the gasket that you are speaking of will chime in on what they have done. Good luck.
Old Jun 15, 2010 | 01:45 AM
BasicConcepts's Avatar
Technical User
this is darlingrejects car???
Old Jun 15, 2010 | 04:21 PM
DarlingReject's Avatar
Prettiest Sixer Around
September 2010 ROTM
Yes, it's for my car.
Racer
Aug 19, 2010 05:47 PM
lowend
70-81 V8 Tech
Dec 11, 2008 06:54 PM
chala
Nov 12, 2008 07:50 AM
Adamloveshis99camaro
Oct 5, 2007 06:10 PM
dvader
Jul 2, 2007 11:17 AM
