Crank Pulley
i assume its a 98 but what motor? im not sure why you would need to remove the starter unless it needs to come off to get the cover off. it is best to use the flywheel to stop the crankshaft from turning so flywheel cover would need to come off. its one of the only ways to keep the motor from turning over when you remove the bolts
yes its tty and no the parts stores don't have it, only gm, zzp and intense racing sell it.
http://shop.zzperformance.com/store/...haft-Bolt.aspx
INTENSE-Racing.com: Crank Bolt
