coolant problems maybe...
Old Feb 1, 2012 | 07:36 PM
tacameron's Avatar
Default coolant problems maybe...
I have a 1999 camaro 3.8 auto I notice that it was using coolant so I pressure tested it saw coolant making its way out the back of the intake so I replaced the intake with the steel gaskets instead of plastic I also changed the valve covers they were leaking. Seems now the coolant in the radiator leaks down about a inch below the flews is this normal or am i leaking/ burning coolant what could be the problem/s
Old Feb 1, 2012 | 07:39 PM
BasicConcepts's Avatar
Technical User
pressure test it again. hows the oil look?
Old Feb 1, 2012 | 07:41 PM
so your losing coolant? so no coolant in oil? did you change both intake gaskets? upper and lower. probly be a good idea to do a compression test on all cylinders. could be a headgasket starting to go.
Old Feb 1, 2012 | 07:46 PM
tacameron's Avatar
i hope it aint the heads i was just there oil looks good I will repressure test it in the morning I replaced upper and lower
JGuy07
Mar 16, 2012 11:22 PM
antperri1222
Dec 13, 2011 06:19 PM
mccoyj91
Mar 20, 2010 04:07 PM
libertyforall1776
May 10, 2007 11:47 PM
user 7208220
Aug 29, 2006 07:07 PM
