coolant problem
i have a 93 3.4 i just replaced the thermostat cause it was overheating just sitting there after a while and the water pump wasnt leaking. I then took off the radiator cap and started the engine and coolant started to come out of the top of the radiator i was just wandering what the h@#@ the problem could be since i=there is no coolant getting to the block or what
Did the car overheat after you replaced the thermo? Not knowing all the details nor alot of info from your original post but that is a sign of blown head gasket pressurizing your coolant system.
yes it is still over heating and what other kind of info would you need
Originally Posted by gville4life
(Post 406685)
it wasnt bubbling out it was flowing out as to ahow that the watrer pump is working but the coolant isnt getting to the engine
no it hasnt been flushed or bled yet
(Post 406676)
Is your car still overheating? Does it consume coolant? Does it have any white smoke (that may smell sweet)? |
Have you installed a Flush Kit, and flushed it? If anyone has ever used stop leak products, that could have clogged up the works, in which case try a Super Flush fluid. All sold at Wally Mart.
i am going to flush it no white smoke or anything
but will a flush work if the coolant isant getting into the block
