coolant color not good!
Old Jun 16, 2011 | 06:48 PM
BigAl619's Avatar
Unhappy coolant color not good!
hey guys i need help does any body know why the color of my coolant would be brown kinda like chocolate milk!
Old Jun 16, 2011 | 07:30 PM
RFxCamaro's Avatar
The fact that its dexcool which is supposed to be good for 100k but actually needs to be flushed every 20k
Old Jun 16, 2011 | 08:42 PM
Grandpaswagon's Avatar
It is probably because it is too old and nasty. If it is original, you definitely need to change it out.
If it is not that old, you may have another problem that is letting oil or combustion gasses mix with the coolant. But it is most likely just old and needing changing.
Old Jun 18, 2011 | 01:37 PM
BigAl619's Avatar
Thanks guys i hope thats all it is! Ill flush it this wknd!
Old Jun 18, 2011 | 01:41 PM
libertyforall1776's Avatar
How many miles since your last flush? Might want to install a flush kit...
Old Jun 18, 2011 | 07:55 PM
AlaJoe's Avatar
How long have you had the car? I ask because I once bought a car that had the same issue. I did not check it until after having the car about six months. I flushed it and the next day a pinhole leak showed up at the intake manifold. I was left with the sneaking feeling someone had put stop leak in the radiator and sold the car. I figured since it worked once lets do it again. I put stop leak back in it and it turned the fluid back to brown but it did stop the leak. I drove the car another few months and unloaded on someone else.
Old Jun 20, 2011 | 05:05 PM
ccrunner1104's Avatar
What about oil getting in the cooling system?
Old Jun 20, 2011 | 06:11 PM
BigAl619's Avatar
Default Out with the old in with the new!
Well i just hit 99,000 miles! Coolant has never been changed! But this past wknd i did a flush, it looked pretty nasty. Flushed it 3 times before it went clear! Also did the hoses, and thermostat.
Size:  18.6 KBName:  IMAG0025-1.jpg
Size:  20.4 KBName:  IMAG0022.jpg
Size:  12.3 KBName:  IMAG0023.jpg
Camaro3800V6
Aug 17, 2011 03:47 PM
AnalyzeFaith
Dec 5, 2010 05:54 PM
dp66ny
82-92 V8 Tech
Dec 19, 2007 02:00 AM
imawesome
Dec 29, 2005 12:40 AM
