Codes PO172 and PO175
I recently found out that my 96 camaro 3.8 was throwingthose codes. They translate to "Fuel trim sys rich bank 1" and "Fuel trim sys rich bank 2". Just wondering if anyone has any experience diagnosing/fixing these codes. The car seems to be running fine, but that Service Engine Soon light is getting annoying! My Camaro has Cold Air Intake and a Flowmaster 40 series exhaust (maybe that has something to do with it??). Thanks.
RE: Codes PO172 and PO175
P0172, P0175
CIRCUIT DESCRIPTION
The powertrain control module (PCM) controls the air/fuel metering system in order to provide the best possible combination of driveability, fuel economy and emission control. Fuel delivery is controlled differently during Open and Closed Loop. During Open Loop the PCM determines fuel delivery based on sensor signals, without oxygen sensor (O2S) input. During Closed Loop, the oxygen sensor inputs are added and used by the PCM to calculate Short and Long Term fuel trim, fuel delivery adjustments. If the oxygen sensors indicate a lean condition, fuel trim values will be above 0 percent . If the oxygen sensors indicate a rich condition, fuel trim values will be below 0 percent . Short Term fuel trim values change rapidly in response to the heated oxygen sensor (HO2S) voltage signals. Long Term fuel trim makes coarse adjustments in order to maintain Air/Fuel Ratio of 14.7:1. The fuel trim diagnostic will conduct a test to determine if a rich failure actually exists or if excessive vapor from the evaporative emission (EVAP) canister is causing a rich condition. If the PCM detects an excessively rich condition, this diagnostic trouble code (DTC) will set. If the PCM detects excessive vapor then a pass is logged.
CONDITIONS FOR RUNNING THE DTC
DTCs P0101, P0102, P0103, P0107, P0108, P0121, P0122, P0123, P0130, P0131, P0132, P0133, P0134, P0135, P0137, P0138, P0140, P0141, P0201, P0122, P0201-P0206, P0300, P0401, P0403, P0404, P0405, P0410, P0412, P0418, P0440, P0442, P0446, P0506, P0507, P1404, or P1441 are not set.[*]The engine coolant temperature (ECT) is between 20-110°C (68-239°F ).[*]The intake air temperature (IAT) is between 18-70°C (64-158°F ).[*]The manifold absolute pressure (MAP) is between 15-105 kPa (2.1-15.2 psi ).[*]The vehicle speed is less than 132 km/h (82 mph ).[*]The engine speed is between 600-4,000 RPM .[*]The barometric pressure (BARO) is more than 70 kPa (10.1 psi ).[*]The mass airflow (MAF) is between 5-150 g/s .[*]The fuel level is more than 10 percent .
[ul][/ul]
CONDITIONS FOR SETTING THE DTC[*]The average Long Term fuel trim value is below -13 percent .[*]All of the above conditions are present for 40 seconds .
[ul][/ul]
ACTION TAKEN WHEN THE DTC SETS[*]The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.[*]The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
[ul][/ul]
CONDITIONS FOR CLEARING THE MIL/DTC[*]The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.[*]A current DTC, Last Test Failed, clears when the diagnostic runs and passes.[*]A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.[*]Clear the MIL and the DTC with a scan tool.
[ul][/ul]
DIAGNOSTIC AIDS[*]Fuel contamination, such as water and alcohol will affect the fuel trim.[*]A malfunctioning MAF sensor can cause a rich condition and set
CIRCUIT DESCRIPTION
[ul][/ul]
[ul][/ul]
[ul][/ul]
[ul][/ul]
