Check Engine Light Help
Old Sep 2, 2010 | 04:08 PM
bchbmjohn9's Avatar
Default Check Engine Light Help
Hi all. I tried to scan my 1994 Camaro (3.4L V6) and the check engine light stayed on. I didn't get a Code 12. Does anyone know what the problem might be?
Old Sep 2, 2010 | 04:44 PM
How did you try to scan it? Hope you realize you can't flash out codes in that car.
Old Sep 2, 2010 | 04:48 PM
bchbmjohn9's Avatar
I used an actron OBD-I scanner that's for my car.
Old Sep 2, 2010 | 05:54 PM
The check engine light will stay on until the problem is fixed. Does the scanner scren show anything?
Old Sep 2, 2010 | 06:04 PM
bchbmjohn9's Avatar
No, I am not even getting the default code 12 showing that the computer is going into diagnostic mode.
Old Sep 2, 2010 | 06:08 PM
Hmmm. What model is the Actron?
EagleRex
May 29, 2010 04:48 PM
ghanahost
Feb 21, 2010 12:49 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
gozzy341
May 20, 2007 11:00 AM
teamlilE1
Mar 12, 2006 02:22 AM
